A Resource for Historic Arms and Armour Collectors
Albion Armorers Regent
Original: Germany, mid to late 15th century
20 people like this. Do you like this? yes no
This sword is made in the style of 15th century cut-and-thrust longswords. Its blade, categorized as Type XVIIIa according to Oakeshott's Records of the Medieval Sword, tapers to a strong point while retaining enough width for effective cuts. It has a pronounced mid-rib due to hollow-grinding, which produces a stiff blade for powerful thrusts that does not sacrifice cutting ability. The hollow-grind does not go all the way to the edge; rather, it terminates about .15" from the edge, allowing for a period-correct reinforcement of the edge.
The pommel is shaped like a fishtail, a variant of Oakeshott's Type V. The octagonal guard flares slightly in width from its center. Simple straight lines serve as effective decoration, from the incised lines on the guard to the line that extends from the blade's mid-rib through the guard's and grip's peaks before splitting off in a V at the pommel.
The grip is of hock-bottle shape and is six-sided. It features cord risers at either end and at its waist and is covered in dark blue leather.
Overall length: 48"
Weight: 3.25 pounds
Width of guard: 9.625"
Blade: 37" long; 2" wide tapering to .5"
Grip and pommel: 10.375"
Point of Balance (PoB): 4.5" from guard
Center of Percussion (CoP): ~23" from guard
Maker: Albion Armorers of Wisconsin.
Chad Arnow's Collection
20 items in total
Swords
Knives and Daggers
Other Items
Show retired collection »
