Go to page Previous  1, 2, 3, 4, 5, 6
Brawn Barber wrote:
Alessio J. Orlandi wrote:
In relation to the evidence of leather armour is that he main problem the organic nature of leather. Say we were to strip off your skin and leave it lying around for 500 years or so. Do you think we would still find it? I think not.
Please, read again what i wrote :)
I've said I know leather was used. There's plenty of sources refering to "cappellum de corio" (leather hat), "curazia" and "correttum" (leather armour), but i've never found an explicit reference to the use of treated leather.
I'm just saying: anyone who says that you can harden leather by immersion in boiling water is wrong, since this would destroy the leather (made exception for 4-5 mm thick sole leather). I've no doubt there are other methods, such as soaking and "cooking" in oven. Unluckily I only have a microwave oven and i don't think it would work properly... :(
What I'm stressing is that I can't find enough historical evidences of "cuir boulli" to justify the fact that everyone is so sure about this subject. I hope i was more clear this time. ;)
Other two cents on the subject: it has been said somewhere in this topic that leather was expensive. Sincerly I have no idea about the cost of leather in medieval age, but surely it was not as uncommon as today (we all know this), since there were battles involving more than 10.000 mounted knights by side, a number of beasts we can't even imagine nowadays. Therefore I can't guess how many horses, cows and bulls where around, but surely they could have made at least some hundreds pair of shoes and leather armours just by using horses dead in battle. I don't know if they used cow skin, horse skin or else, but surely they didn't lack any leather if they could afford to send in battle so many horses. Therefore I think (IMHO) that leather armour was not so expensive. Surely there was a wide range of prices and qualities.
cooked?
Dan,
bouilli does mean boiled... Cooked, or baked, or heated would come out ''cuit'', ''roti'' ''chauffé''.
As a noun, un bouilli, means a stew, in other words meat cooked in a liquid, with vegetables. Bouillon is broth.
As a verb,bouillir, means to boil.
Now I will grant you that all liquids will boil at the approriate temperature, so we might be dealing with a construct more complex than simple water, but that does not change the meaning of the word. Cheers, Jean-Carle
Actually more like "poached", not hard boiled. "Court Bouillion" is a solution of vegetables in water in which Salmon is "poached" . Boil it and you'll lose the steak which will fall apart during the boiling process. I believe the Bouille reference rather than a "rolling boil" is the effect here same as the fish. You don't want it to boil. It's great with a little Hollandaise on it.
poached
Brawn,
not really. Poached is ''poché'', like for eggs benedictine: des oeufs pochés, .. boiling oil is huile bouillante, and so on.. ébouillanter is to splash with a boiling substance.. being scalded...
Now there is the exprssion : réduire en bouilli... which means to transform something into mush, and by extension, one can reduce one's adversaries into nothing by making mush out of them... les réduire en bouilli...but that is an extension of the basic image of what happens when you leave anything boil too long, it will eventually turn into mush.
Cuir bouilli is quite litterally boiled leather, though how and with what and for how long, is still up for debate. The language in itself is not really to interpretation...JC
I found an interesting note in the Oxford English Dictionary on cuirbouilli
in addition to showing various forms of spelling the word; it gives the literal meaning as being "boiled leather" (pg. 1241, 1971 edition)
The definition strongly implys that the leather is soaked or 'boiled' in water to make it pliable in order to facilitate forming the leather into the required shape.
"Leather boiled or soaked in hot water, and, when soft, moulded into any required form; on becoming dry and hard it retains the form given to it, and offers considerable resistance to cuts, blows, etc."
(the note I found interesting) "The word was in common English use from the 14th to 16th c. after which it is not found until modern times, when it appears as borrowed from modern French"
The OED also references an 1880 publication by C.G.Leland 'Minor Arts' which also indicates that the boiled or 'macerated' leather was for softening the leather prior to working it into form.
In searching for an existing copy of Leland's work I found the following URL, which may be useful:
http://www.personal.utulsa.edu/~Marc-Carlson/leather/hl.html
It seems clear, from the information that I have found, that 'boiling' is done to simply soften the leather in order to work it; the hardening process comes afterwards from the leather simply drying out on its own, or being put in rosin bath (which incidently needs to be heated), or another treatment to further harden the leather after shaping it.
From hands on experience, I can tell you that modern veg tanned leather does not 'soften' when boiled. It in fact shrivels and becomes some kind of ultra tough crap. Emphasis on crap. I could find some uses for it, but it's really distorted looking.
I am still currently of the belief that the leather is *tanned* in a different way (that's the word for it, right?).
M.
The problem with modern leather, even vegetable tanned one, is that the leather is stretched and pressed to obtain an uniform thicknes... different parts of the leather piece are pressed and stretched differently so when it's shirnks in boiled water, it will shrink differently. This wouldn't happened with medieval leather that was stretched only on a wooden frame by hand.
working leather
M. Eversberg,
my experience was different from yours. I think the trick is to have your form or mold ready so that the leather is stretched to the proper shape, and then blocked so it doesn't move during the drying process. I used an old wood form for making hats and in one instance made a plaster of paris mold of the inside of a motorcycle helmet to get the proper head side.
One thing I did notice is that the leather will still shrink a little, even after it appears to be dry I made a couple of leather skull forms, which my friend Dabek banded with metal, spangen style, and finished it off with butted mail. I sold them at Pennsic years ago to people who enjoyed a pseudo viking look.
Once dry, I used some varnish that I had hanging around in the basement, which I colored with wood stain. I still have mine, though it is now being used in some LARP by my sister in law's beau. JC
I willingly cede that I might be wrong in all points I've made thus far :p
Now, when I boiled the leather, it decided to become all gnarly in the pot, and the water wasn't quite a "rolling boil". I think it warrants experiment, and I do have some scraps, but I'd prefer to do it on actual period leather. This would be well out of my price range.
M.
Depends on where you get it. The half hides I pick up from Tandy are not uniform in thickness.
Steven
M.
is very important to address the leather from dealers who have environmental certification. Indian Leather industry, place colors and highly toxic. When the skin or leather is boiling, releasing these substances. In the Italian footwear industry, we will ask for a certificate in accordance with environmental regulations.
In particular, are toxic:
Chromium VI
formaldehyde
Pentachlorophenol
chromium oxide
Maurizio
Re: cooked?
Jean-Carle Hudon wrote:
Dan,
In modern French yes. The Medieval definition of bouilli seems to be much broader but I'd defer to someone who has studied the language more thoroughly.
Re: poached
Brawn,
JC,
I was not attempting to literally translate but rather express the relation of the term's use in the application. I am merely stating that it was referring to a relative temperature of immersion.
poached
Brawn
Got it. Didn't want to get anyone in hot water on a question of a simple variation in degrees... I have a few more puns in mind, but that should do for now... Cheers, JC
Yes that was my point also. In English the word "boiled" means that the water must be at boiling point. With the medieval "bouilli" I'm not sure the same thing is implied. The water could be cooler and the term can still apply. But like I said I don't study medieval French. I was merely attempting to trace the etymology of a single word.
litteral
Dan,
I understand the hypothesis, and I wasn't standing there with a thermometer in hand, but water doesn't boil at different temperatures according to language groups, and bouilli does mean boiled. Now even in english we might say that the weather is boiling hot, when in fact it isn't... we refer to people being fried when in fact they're not.. and so on.. but that doesn't alter the plain and simple meaning of words : bouilli is boiled... now whether or not they truly did bring the leather in the water up to a boil, or wait until the liquid ( whatever it was ) boiled before ''poaching'' the leather, I really don't know.. but I do know that there is no difference between boiled or bouilli, so I guess we will have to continue looking for the magic recipe.
I knew one fellow who made leather masks which he would sell at pennsic, or Renfairs... he used fabric softener as a component of the liquid bath to soften the veg tanned leather before forming them into all sorts of shapes. but I know that fabric softener wasn't around in the 1200's...
Lâche pas mon ami,
JC
Today we use the word to refer to a very specific instance - where the liquid is heated up to the point in which it begins to convert into a gas. That was definitely not the definition in the past. The word was used to describe a hot liquid - that is it. "Boiling in oil" just meant that the person was tortured by dumping them in hot oil. "Boiled leather" just meant that the leather was treated by using hot water. Whether the liquid had reached "boiling point" was irrelevant.
Idea about "cooking" leather: press the leather between two wooden tables, then put them into boiling water and let it dry. Then leather should shrink and harden but maybe at the same time it could keep a "normal" flat shape, without curling, and it would be of some use. I will try tomorrow...
Page 6 of 6
