Pommel decorations on Scottish dirks?
Hi all,
Many dirks from the 17th and 18th century feature nice decortive lines and patterns on the top of the pommelplate.
When I was working with my dirk project recently, I had no clue about this. To decorate the pommelplate, I simply used some fine files and made some simple lines which formes a cross. This I think looks OK, but how does one make sircles etc.? Please tell me how the historical method would be, since I prefer to do most of the job without electric tools.
Henrik
You use a circle/round punch and hammer. Just be sure to practice first abit to get the technique to strike without rocking to one side or the other to get a goodlooking/perfect circle.
Kirby makes his own for whatever size hole needed but you can also find steel counter punches.
Thanks Laurie!
You're a great help!
Does brass need to be heated in any way before this is done?
Henrik
Henrik Bjoern Boegh wrote:
Thanks Laurie!
Henrik
If the brass has been work hardened a lot, you should anneal it(heat it and drop it in some water). Just wondering; are you using brass sheet from Clas Ohlson(that stuff does almost _never_ need to be annealed)? I can attest to what Laurie is saying; definately practice! I went through a lot of scrap pieces before I could get a circle that looked nice...
Johan Schubert Moen
Having the brass on an anvil or something that won't bounce will help a great deal.
Thanks!
Does one have to get special tools for this?
Johan, you're right, I've bought brass sheets from Clas Olsson (in Kristiansand, actually :D )
Henrik
