15th century messer by Elchon's Workshop
Hello again.
I want to share with you my latest project.
It's a messer inspired by 15th century finds.
The overall lenght is circa 61,4 cm, weight 0,6 kg. It's made from very tough nz3 tool steel (it is sometimes used for jack hammer chisels). The handle is water buffalo horn.
The blade was made by grinding, but I used some hot forging for the crossguard, nagel and pommel.
Some work-in-progress pics:
A short movie : https://www.youtube.com/watch?v=ZXAuLtV4xKM
Than I've decided to change the simple nagel for the more interesting st. Jacob's shell :)
This picture clearly shows the size of the messer. :)
And finally the messer is finished. Here are some pics. After taking pictures I decided to round the upper corners of the pommel a bit for more comfortable grip. Anyway the difference is very slight, so the pictures are true to the current state in 99,9% ;). I'll take new pictures when I finish the scabbard.
a nice one! I really like those clean and simple lines. Just a technical question: in the first picture I see three holes in the tang. Then, the finished messer has 3 rivets plus nagel - did you drill the hole for the nagel after the final assembly?
Radovan - I drilled it before assembling scales. This part of the tang wasn't tempered as much as a blade, so it was quite soft. It could be drilled using the special drill with cemented carbid tip. :) The reason why I did it at this stage is because I wanted a close fit of the nagel to the cross guard.
Michal:
Simply splendid. Elegant in design, but obviously quite functional.
Excellent work, sir.
Regards, Jon
That looks awesome. Someday, when I have the extra money I may have to hit you up to make me something similar.
That is very nice.
Well done and congratulations.
A most avesome knife!
May i ask how thick is its spine?
Thanks guys. I'm glad you like it.
It is circa 4,6 mm at the guard, but it has some distal taper.
I had some time to finish the scabbard. It is made of wooden core and tooled calf leather. The piece is finally finished and complete :)
Hi Michal :)
excellent work.... work of Art.
best wishes
