Andrew Gill
Posted: Fri 20 Feb, 2015 5:59 am Post subject: |
There is a small, very slightly curved, somewhat corroded messer in the Kelvingrove museum in Glasgow that is relevant to this thread. There are some photos of it in this thread :http://www.myArmoury.com/talk/viewtopic.php?t...w=previous (note: not the sabered arming sword also discussed in that thread). I think the blade was only around 70 cm long (I have better but still approximate dimensions for it written down somewhere - taken through glass with a tape measure, so the error of parallax is included free of charge). When I saw it about 5 years ago, it struck me how similar it was to those depicted in Talhoffer's manuscript, as shown earlier in the thread. It definitely had a nagel, and clearly had once had grip-scales rivetted onto the tang, though they are long gone now. The interesting thing about the blade was that instead of a clipped point it had something like a spear-point (i.e an almost symmetrical point sharpened on both sides), and even in the unsharpened portion of the back between the hilt and the false edge had bevels, so the blade had a sort of assymetric or mutilated diamond shape over its entire length.
T. Kew
Posted: Fri 20 Feb, 2015 7:38 am Post subject: |
Andrew Gill wrote: | There is a small, very slightly curved, somewhat corroded messer in the Kelvingrove museum in Glasgow that is relevant to this thread. There are some photos of it in this thread :http://www.myArmoury.com/talk/viewtopic.php?t...w=previous (note: not the sabered arming sword also discussed in that thread). I think the blade was only around 70 cm long (I have better but still approximate dimensions for it written down somewhere - taken through glass with a tape measure, so the error of parallax is included free of charge). When I saw it about 5 years ago, it struck me how similar it was to those depicted in Talhoffer's manuscript, as shown earlier in the thread. It definitely had a nagel, and clearly had once had grip-scales rivetted onto the tang, though they are long gone now. The interesting thing about the blade was that instead of a clipped point it had something like a spear-point (i.e an almost symmetrical point sharpened on both sides), and even in the unsharpened portion of the back between the hilt and the false edge had bevels, so the blade had a sort of assymetric or mutilated diamond shape over its entire length. |
Do you have a catalogue number? I'm up at the Kelvingrove in a few weeks, and that's quite a nice little piece.
(I can see about inquiring about blade profile and measurements etc, but obviously no guarantees)
Jeffrey Faulk
Posted: Fri 20 Feb, 2015 8:27 am Post subject: |
People didn't use messer to clear woods because they had other tools much better suited to the purpose. Bill-hooks and axes, to name two. I am fairly confident in stating that messer were almost always intended as weapons and generally used for that purpose, although they could have occasional non-combat uses; slaughtering animals, perhaps.
Mike Ruhala
Posted: Fri 20 Feb, 2015 3:19 pm Post subject: |
James Moore wrote: | Mike Ruhala wrote: | An illumination from a 13th c. manuscript shows a normal beidana being held in luginslant and wielded with a buckler, having evidently just wounded the head of kneeling saint. |
could you provide a source for that illumination? From what I've heard, Beidana only appeared in the 16th Century.... |
Sure! Had to look it up, apparently it's the martyrdom of St Peter.
http://www.metmuseum.org/collection/the-colle...arch/32830
Mark T
Posted: Sun 22 Feb, 2015 1:28 pm Post subject: |
Michael Brudon wrote: | Also would like to ask what is the purpose behind the clip points, I think also shown on dussacks? It seems to be a deliberate limiter to penetration, maybe for sparring or competition fighting? Or was it just a shortcut to build a basic heavy spine and at least give it some sort of point ? |
Hi Michael,
There's been some good modern research done on the effectiveness of clip points in the context of sabres and bowie knives.
In brief:
- They reduce weight at the tip, but still allow for an in-line point.
- The meeting of the convex with the concave edges allows for a finer - and therefore sharper - point than a dagger (or 'double-convex' point).
- The fine angle of the 'true' edge is backed up by the thicker 'false' edge, creating a larger, triangular wound channel.
- While a normal convex edge will work in a repelling motion, the concave edge can act in a pulling motion, which can be more efficient in both the cut and the retraction.
- The sharpened swedge / false edge allows for back-cutting techniques, which would not be as effective with a standard 'dagger'-shaped point.
If you want more information on this, good leads are:
- Master-at-Arms James A Keating's Bowie knife fighting DVDs: http://www.jamesakeating.com/, as well as the good overall introduction on his 'Legacy of Steel' DVDs, available from both Mr Keating and Paladin Press.
- Master Bladesmith Bill Bagwell's video commentary on Bowie knives. You can see part of this on the relevant Modern Knives DVD issue, available from Pete Kautz: http://alliancemartialarts.com/issue5.htm, as well as 'Bill Bagwell: Point and Back Cut' on YouTube: https://www.youtube.com/watch?v=KuZlPJBA61I
- Bill's 'Bowie's, Big Knives, and the Best of Battle Blades': http://myArmoury.com/books/item.1581601077.html has a good discussion of the features and benefits of this geometry
- Maestro Charles Selberg's YouTube video response to my questions about these issues, 'Sabre Fencing: The History and Use of the Back Cut or False-Edge Cut in Sabre Fencing': https://www.youtube.com/watch?v=cw-yNdbXE8Q
In short: sharpened clip-points existed for a reason: they worked!
Schallern sind sehr sexy!
Michael Brudon
Posted: Sun 22 Feb, 2015 8:24 pm Post subject: |
Thanks for the information, very interesting!
Luka Kren
Posted: Fri 17 Jan, 2020 4:10 am Post subject: |
Sean Flynt wrote: | Here are two messers with softer tapers, but notice the length.
See this old thread for details and good info. |
Hi, do you perhaps have any more information on the first messer you posted? I'm interested in its dimensions...
Thanks
Luka
https://www.facebook.com/lusthallworkshop/
JG Elmslie
Posted: Sun 19 Jan, 2020 2:28 pm Post subject: |
I know its rather late now, but just be aware that the second of those two messers is possibly a fake.
Michael P. Smith
Posted: Thu 30 Jan, 2020 5:24 am Post subject: |
I’m surprised that no one has mentioned the English Wakefield-type hangers. They are “messer-like” but sport a tip better suited to thrusting and a sword-like grip construction.
