Forum Index > Historical Arms Talk > Does anyone know where the original is? Reply to topic
Russ Ellis
PostPosted: Sun 17 Apr, 2005 8:06 pm    Post subject: Does anyone know where the original is?         Reply with quote
http://www.deltin.net/5149.jpg
Does anyone know where the original of this sword currently resides? I've already asked Mr. Del Tin about it and he himself does not recall. He believes that it might be in the Royal Armoury but was not sure... anyone?
TRITONWORKS Custom Scabbards
Alina Boyden
PostPosted: Sun 17 Apr, 2005 8:29 pm    Post subject: Re: Does anyone know where the original one of these is?         Reply with quote
I don't know anything about it, but could you tell me what it is? IE, typology or date or something?
View user's profile
PostPosted: Sun 17 Apr, 2005 8:37 pm    Post subject:         Reply with quote
Including some information to help people is necessary. This is what Del Tin's site says: "14th CENTURY SWORD. Overall length cm 112, blade cm 91. Weight 1640 gr."
Alexi Goranov
myArmoury Alumni
myArmoury Alumni
Reading list: 72 books
PostPosted: Sun 17 Apr, 2005 8:52 pm    Post subject: Re: Does anyone know where the original one of these is?         Reply with quote
There is a similar sword in the Royal Armouries Tower of London (IX-1084). It has similar pommel (although the boss is smaller and does not have a recess) and similar cross. This sword is 107.9cm in length (overall). It has a small fuller in the upper 1/3 of the blade (like the Del Tin). the single biggest difference is the presence of the large side fullers on the Del Tin. The sword is dated to the fourteenth century.
Picture is included.
Alexi
 Attachment: 50.57 KB
PostPosted: Sun 17 Apr, 2005 9:04 pm    Post subject: Re: Does anyone know where the original one of these is?         Reply with quote
If you look closely at the Tower sword, it looks to have 2 shallow fullers (or severe hollow-grinding) between the small fuller and edges.
PostPosted: Sun 17 Apr, 2005 9:37 pm    Post subject:         Reply with quote
Alexi, that's a damn good catch. I think that the hilt is extremely close on that one. As Chad points out, I do see the signs of fullers or hollow-grinding as well.
Patrick Kelly
PostPosted: Sun 17 Apr, 2005 9:43 pm    Post subject:         Reply with quote
I don't know if those are fullers or if it's simply a strong secondary bevel at the edge. Even if it's the latter Fulvio may have interpreted it as a fuller. Either way I'd say this is a strong candidate Russ.
Brian M
PostPosted: Sun 17 Apr, 2005 11:33 pm    Post subject:         Reply with quote
Definitely an interesting blade on the Del Tin, don't know if it's a correct interpretation of the original, but it is interesting. A fullered mid-rib flanked by shallow fullers.
Hmm, I swear I've seen a picture of that sword or a very similar one on a book cover recently...
I just checked it out and I was right. I noticed it at the local Half-Price Books and I just looked it up on Amazon. Title is "King Arthur: Dark Age Warrior and Mythic Hero" by John Matthews. On close inspection it's not the same sword, but it is very similar. The blade has some pretty strong secondary bevels and a narrow central fuller. Same pommel and guard too. Check it out for comparison.
Anyone know which sword this is on the cover? I don't have ROTMS.
Brian M
Russ Ellis
PostPosted: Mon 18 Apr, 2005 6:54 am    Post subject: Re: Does anyone know where the original one of these is?         Reply with quote
Alexi
Alexi may I just say... NICELY done! I think you've got it. On a purely visual level it's darned close and combine that with Mr. Del Tin's clues about where he thinks he may have found the original...
I certainly appreciate it sir!
Russ Ellis
PostPosted: Mon 18 Apr, 2005 6:56 am    Post subject: Re: Does anyone know where the original one of these is?         Reply with quote
Agreed. The picture is a bit rough but there definitely looks to be an edge bevel between the fuller/hollow grind and the edge of the sword.
Russ Ellis
PostPosted: Mon 18 Apr, 2005 6:57 am    Post subject:         Reply with quote
Agreed!
Russ Ellis
PostPosted: Mon 18 Apr, 2005 7:00 am    Post subject:         Reply with quote
Brian M
Pommel and guard look pretty darned close, the blade cross section is extremely different. Of course with Mr. Del Tin that still doesn't mean that the same sword couldn't have been used for the model. I've noticed with Mr. Del Tin that he has no problem interpreting originals when enough hard data isn't available, in effect relying on his own knowledge and experience as to what makes a good sword when he has to.
Allen W
PostPosted: Mon 18 Apr, 2005 8:28 am    Post subject:         Reply with quote
I'm pretty sure that's XVIa.1 from RoMS.
Russ Ellis
PostPosted: Mon 18 Apr, 2005 10:59 am    Post subject:         Reply with quote
I'll check that out when I get home...
Patrick Kelly
PostPosted: Mon 18 Apr, 2005 11:15 am    Post subject:         Reply with quote
I don't think that's it. I have the DT sword here now and it's far closer to the example that Alexi posted. The blade's cross-section and the guard style are much closer to that one.
Russ Ellis
PostPosted: Mon 18 Apr, 2005 8:40 pm    Post subject:         Reply with quote
Well having looked at the picture of XVIa.1 I'd have to say that the cross is completely different then the replica although based on the pictures we have I couldn't say for sure that the Del Tin sword isn't an amalgamation of the two. The XVIa.1 does appear to have a not completely disimilar cross section although the central fuller is rather a lot longer then on the Del Tin sword. The pommels are pretty close as well between the two swords.
Thanks so much for your help gentlemen...
Joe Maccarrone
PostPosted: Wed 20 Apr, 2005 12:36 am    Post subject:         Reply with quote
Interesting thread... I woulda sworn I saw a triple fuller in the pic Alexi posted, but -- Royal Armouries IX.1084 is XVIa.5 in RoMS. Concerning the fuller, Oakeshott writes:
"The fuller here is very narrow, but there is a distinct rib in the lower half of the blade."
No mention of a triple fuller. Now that I read that, I can see the rib, and either a secondary bevel, as Patrick speculated, or a hollow grind. I would think that Oakeshott would have mentioned the latter, so maybe it is a prominent secondary bevel on a blade intended primarily for thrusting. Either way, an appealing sword, which Oakeshott dates c.1300-25.
Edward Hitchens
Reading list: 9 books
PostPosted: Wed 20 Apr, 2005 6:50 pm    Post subject:         Reply with quote
I don't know, fellas. I've got my copy of Records right here in front of me (type XVIa.5), and Oakeshott has the blade at about 84 centimeters; according to Nathan, DT's website has their replica's blade at 91, right? Oakeshott also says there's a "...distinct rib in the lower half of the blade." Looks to me like the original has a pommel nut as well.
-Ted
PostPosted: Wed 20 Apr, 2005 7:30 pm    Post subject:         Reply with quote
Well I hope there is some justification for it historically because I really like those multiple fullers.
At the very least it would be a great fantasy piece.
If documented an Albion or A & A version would be very tempting: Very nice design Cool
I might even be tempted to design my own Fantasy version of it if I ever went the custom route.
Hmmmmm..... something combining a type XIV with a type XV reinforced point using this pattern of fullers maybe.
(Edited to add graphic: What it might look like as mentioned above. )
 Attachment: 75.4 KB
Björn Hellqvist
myArmoury Alumni
myArmoury Alumni
PostPosted: Mon 25 Apr, 2005 1:35 am    Post subject:         Reply with quote
Why not ask Fulvio? He usually backs up his designs with some kind of documentaion.
My sword site
