Forum Index > Off-topic Talk > How far a sword could cleave Reply to topic
This is a standard topic Go to page Previous  1, 2, 3
Rod Parsons
Reading list: 11 books
PostPosted: Sat 15 Jul, 2006 3:37 pm    Post subject: Padding, under or over maille?         Reply with quote
Dan,
What is your view of the efficacy of padding over maille as with an aketon as opposed to padding under maille?
Any information or comment would be welcome.
Rod.
PostPosted: Sat 15 Jul, 2006 7:10 pm    Post subject: Re: Padding, under or over maille?         Reply with quote
Rod Parsons wrote:
Dan,
Rod.
Not to answer for Dan, but I think that padding worn under maille would be thinner and mostly an arming coat giving mostly protection from blunt trauma. This same thin " gambison " would only be very light protection if used on its own.
The padding worn over maille would be much thicker and of some real value as protection used alone by itself.
A thin gambison or arming coat would still be used under the maille when a thick one was used over the maille I believe.
I would think that the fabric would clump around an arrow point and make the piercing of the maille MUCH more difficult: The energy being spread out rather than concentrated on one link of the maille.
Sharpness of the point should make a big difference with cloth armour: If razor sharp a point might cut through easily, but anything less than razor sharp means having to spread the fibres of the weave apart or break the fibres and even a needle point would have trouble piercing if not followed up by razor sharp edges past the very point.
All conjecture on my part i.e. " Opinion " I could be wrong. Wink
Page 3 of 3 Reply to topic
Go to page Previous  1, 2, 3 All times are GMT - 8 Hours
