Bearded axe and Warhammer
Hello again..
Here are couple of pieces I made about a year ago, just wanted to share them with you other enthusiasts
So, the bearded axe is trying to raise some viking spirit with its looks. It is 66cm long, and weighs about one kilogram. I took a little shortcut in the making process I bought a cheap, LARGE axe(I think it was about 8€) and modified it into this. I used angle grinder to cut the shape, and belt sander to clean the surface, since it was covered with paint. The handle was also lacquered, and I sanded it clean. After sanding I dyed and waxed it. The blade quality is not much to talk about. While cutting it to new shape, I revealed some hollow points that were inside the blade Guess it was welded into one piece where ever mountainside it was made...
And on we go with the warhammer...Itīs 73,5cm long and the weight is maybe a bit over one kilogram(havenīt measured). The "blade" is milled and sanded from mild steel. The langets(or what do you call them?) are also mild steel, and made of one piece, bended over the "blade". "blade" is riveted into its place through the langets. The langets are then riveted through the handle with four rivets, so the structure is quite durable. Handle is dyed ashwood. I have thought if that handle should have been a bit longer, since the front part is quite heavy...
I had the advantage to use proper tools making these things at my school workshop, so it didnīt take too long to finish them. I would eagerly want to test especially the warhammer with an old car or something as much as fun :lol:
 Attachment: 84.44 KB
axe [ Download ]
 Attachment: 84.15 KB
axe blade [ Download ]
 Attachment: 81.93 KB
warhammer [ Download ]
 Attachment: 89.13 KB
warhammer close-up [ Download ]
Very nice!
Does the shaft of the warhammer extend through the head or is it just butted on top? How was it done historically?
Nick
To Nick:
The shaft doesnīt go through the head, itīs just butted on top with the rivet going through. I thought about making a spike on the top, and it might have been a good idea to then install that spike through the head and into the shaft. Didnīt do it after all. The way I made it, the construction is quite strong, and there is not very much distress pointed to the shaft. The head also keeps firmly on its place.
Iīm not quite sure, is this historically how accurate, but I remember that I have seen something like this...anyway, it works just fine ;)
The axe came out very good congratulation. I love it.
But you said you just bought a wood axe and reshape it into a beard axe?
Nice done it yourself projects.
Cosidering your raw materials,
that bearded axe is beautiful! Congratulations. (I should know, I've seen many awful bearded axe abominations)
If you make the edge very sharp and reduce the edge-shoulder you can hold it 'inside' the beard and get a great planing action.
As for the warhammer I really like the simple head, I'd just shape the sides of the langets? to make them more handmade-looking, or even tapered from top to bottom.
Great work.
Thanks.
To Etienne: Yes, it was a large wood axe that I reshaped with anglegrinder.
To Michael: Thanks for the tips. I also think that I could have removed some more material from the axe and make it a bit more lighter. And itīs true that the langets on the warhammer might have needed some more shaping. Guess I wanted to finish the piece as quickly as possible...also wanted to keep it simple. The hammer is quite heavy for itīs size(I think), so the shaping of the langets might have reduced the weight also. The weight gives a good swing and powerful hit, but itīs not too quick to handle.
Can you give me the measurements of the axe head? (lenght,width and weight)
I put the dimensions to the picture attached. Hope it helps. I didn't have anything at hand to measure the weight so it will have to wait. I would call it light rather than heavy, if it helps ;)
Feel free to ask if you need more measures.
-T
 Attachment: 91.75 KB
axe head measurements [ Download ]
thanks it'll help if i want to do some competition with your axe and my future creation! ;)
I am COMPLETELY in love with that axe.
Everything about it screams 'PERFECT' to my sense of aesthetics.
Well...I'm overwhelmed with pride :D
Glad you like it.
-T
That axe is a great idea. I might have to try that myself. It looks really wonderful. Very smooth lines. You must have spent a lot of time on the grinder!
Mike
thanks again.
Actually it was quite easy to work with, and took maybe about 2-4 hours to finish. I grinded the basic form with a large angle grinder, and used a belt sanding machine to smooth the lines. When you do some work with an angle grinder and get familiar with it, it's actually very handy to work with.
-T
^AGREED.^
I never would've guessed that it began as a "modern" axe-head.
Out of curiosity, what overall length did you make the handle? It isn't obvious in the photos, & I don't recall seeing it in the thread previously.
Thanks,
John
Thanks,
John
Thanks again.
The overall length of the axe is 66cm, as I said in the first post ;)
-T
Toni R. wrote:
...as I said in the first post ;)
Oops, reading comprehension is my friend. :blush: :D
Thanks anyway, I think I might try to have a go at a project like this. We'll see what happens...
