Nate C.
Posted: Sun 13 Jun, 2004 9:21 pm Post subject: Modern vs. Period Tang Construction |
Greetings all,
I am curious about the comparison between modern methods of tang construction as compared with period methods. I am new to the "real" sword world although I have been sport fencing for quite a while. as a newcommer to this realm, the variety of methods used today are a bit confusing. Is a welded tang a viable option, or are one piece weapons more desirable?
Thanks,
Nate C.
Sapere Aude
Andy Bain
Posted: Mon 14 Jun, 2004 1:05 am Post subject: |
Typically you want to avoid welded tangs like the plague. However, some makers can make a strong welded tang. Check out www.lutel.cz and have a look at the pictures of how they construct their welded tangs. I have yet to hear about someone having a problem with one of their tangs.
Jason Dingledine
Posted: Mon 14 Jun, 2004 2:42 am Post subject: Re: Modern vs. Period Tang Construction |
| Nate C. wrote: | Greetings all,
Thanks, |
Hey Nate,
Here is an article that Howy put together in order to explain how we do things at Albion, but it gives you a basic overview of what the current modern construction methods are like.
http://www.albionarmorers.com/functional.htm
Jason Dingledine
Nate C.
Posted: Mon 14 Jun, 2004 11:56 am Post subject: |
Thanks for the help guys. I figured that a welded tang would be bad news but wanted it confirmed. Although those Czech (I think) guys have an interesting approach. Jason, I am assuming that the albion tangs are all milled as part of the blade and the hot peened? It didn't explicitly say so but that's what I got from reading the article. BTW can't wait to read the other articles when they are available.
Thanks,
Nate C.
Sapere Aude
Michael Pearce
Posted: Mon 14 Jun, 2004 12:27 pm Post subject: |
Welded tangs can be quite strong, but many importers of lower-end weapons have tarnished the welded tang through thier poor quality control. I prefer to avoid welding on a tang, myself. The peening method used by many companies is the most period for most pieces, and done correctly is quite strong. The method used by myself and Atrim with the counter-sunk nut is also very strong, as is the hybrid 'nut and peen' that A&A used to (still does?) use. The basic rule is less for a specific type than for the overall quality of the piece- a very high-quality piece is liable to have better construction than a poor one. Alas, it's also likely to cost more.
Michael 'Tinker' Pearce
