Forum Index > Historical Arms Talk > Show Us your Scabbards Reply to topic
This is a Spotlight Topic Go to page Previous  1, 2, 3, 4, 5  Next
Lukas MG
PostPosted: Tue 26 Mar, 2013 12:51 am    Post subject:         Reply with quote
I only have one sword with a scabbard. Both made by myself:
Roger Hooper
PostPosted: Tue 26 Mar, 2013 4:03 pm    Post subject:         Reply with quote
Here is an early ATrim DD1601 Type XIX with a scabbard made by Eric McHugh.
 Attachment: 97.84 KB
DD1601
 Attachment: 98.27 KB
DD1601
Lloyd Winter
PostPosted: Tue 26 Mar, 2013 6:17 pm    Post subject:         Reply with quote
Albion Kingmaker with Christian Fletcher Scabbard,
Belt fittings are a combo of Tod's Stuff and Raymond's Quiet Press
Matthew Bunker
PostPosted: Wed 27 Mar, 2013 4:25 am    Post subject:         Reply with quote
Robin Smith wrote:
Matt, where do you get your brass bits from? You always have the best brass bits...
Cheers Robin,
If they can be made by cutting, drilling, filing, hammering etc then I make them myself.
If it involves casting then I farm it out.
Roger Hooper
PostPosted: Fri 29 Mar, 2013 10:32 am    Post subject:         Reply with quote
Here is the scabbard for my Arms and Armor German Bastard sword. Not the flashiest, but still very good work.
 Attachment: 98.93 KB
 Attachment: 95.41 KB
 Attachment: 98.91 KB
Guy Bayes
PostPosted: Fri 29 Mar, 2013 11:31 am    Post subject:         Reply with quote
Albion Dane, DKP scabbard
 Attachment: 49.33 KB
 Attachment: 46.87 KB
 Attachment: 42.08 KB
 Attachment: 48.74 KB
Taylor Ellis
PostPosted: Fri 29 Mar, 2013 8:45 pm    Post subject:         Reply with quote
Another one by Jeff Helmes:
 Attachment: 60.97 KB
 Attachment: 56.3 KB
Jeff said the tooling design is a combination of the design from the back of the Lewis Chessmen and a Liturgical comb from the 12th century.
Artis Aboltins
PostPosted: Sat 30 Mar, 2013 12:05 pm    Post subject:         Reply with quote
Reworked one of my older scabbards a bit - a conjectural reconstruction of Valsgarde 8 scabbard, using a wooden strap bridge. On the next version I will use a thinner leather, because this is thicker, carving under it is barely visable.
 Attachment: 126.92 KB
 Attachment: 228.73 KB
John Wills
PostPosted: Sun 31 Mar, 2013 3:15 pm    Post subject:         Reply with quote
This is a scabbard I "made" today. It's actually a plastic scabbard owned by one of the young lads in the group I was asked to make look better with some leather, me being me I couldn't just wrap it in a bit old hide. Aimed for a 10th century look to it, nothing too fancy because the lad plays a recent Christian convert.
 Attachment: 75.45 KB
 Attachment: 62 KB
grim guðplega, ær we gofol syllon!
PostPosted: Thu 04 Apr, 2013 7:21 am    Post subject:         Reply with quote
Here are some of the more interesting sword scabbards I have or used to have (by the old guard of scabbard makers):
Albion Sovereign Scabbard by Aaron Schnatterly and Kevin Iseli:
Armour Class Cup and Ring Basket Hilt Scabbard by Art Elwell (nickel silver fittings and a heart shaped stud):
Del Tin 2150 scabbard by Art Elwell (no longer in my collection):
Eric S
Reading list: 8 books
PostPosted: Thu 04 Apr, 2013 2:30 pm    Post subject:         Reply with quote
The short version of the Ottoman kilij sometimes known as ''pala'', with deeply curved wide blade and ‘T’ spine, it was in use from the early 17 C. for more than 300 years well into the 20th C. The hilt of classical form is made of brass cross guard and horn grips with bulbous pommel and brass grip strap. The original wood scabbard is covered with leather and has spiral brass stitching, mounted with chased brass locket and chape, 27 inch blade, 33 inches total.
Terry Thompson
PostPosted: Fri 05 Apr, 2013 5:07 pm    Post subject:         Reply with quote
Definately on the plain side of the spectrum here. So far most are only wood cores. But every blade is protected.
Roger Hooper
PostPosted: Thu 11 Apr, 2013 7:29 pm    Post subject:         Reply with quote
Here is a Del Tin DT2164 (the retired Cinquedea) with a great scabbard by Art Elwell - German silver throat and chape
 Attachment: 95.03 KB
PostPosted: Thu 11 Apr, 2013 10:15 pm    Post subject:         Reply with quote
Below is a scabbard made by Christian Fletcher that accompanies my Albion Soldat Grosse messer. It holds a by-knife and pricker created by Leo "Tod" Todeschini of Tod's Stuff: Also pictured is a Tod's Stuff Hauswehr.
PostPosted: Thu 11 Apr, 2013 10:16 pm    Post subject:         Reply with quote
Below is a landsknecht sword scabbard in the 16th century style to accompany my E.B. Erickson Landsknecht Sword:
Click photos to see full-sized versions
Zach Luna
Likes: 11 pages
PostPosted: Wed 17 Apr, 2013 10:34 pm    Post subject:         Reply with quote
Dan Dickinson scabbard for my Albion Squire:
Valiant Armoury CSS scabbard for my Christian Fletcher/Angus Trim Venetian Bastard Sword:
Scabbard/Saya I modified for my Hanwei Bamboo Mat Katana:
Matthew Bunker
PostPosted: Thu 02 May, 2013 2:47 pm    Post subject:         Reply with quote
Just finished one that I've wanted to make for a long time. It's one of the ones found in the harbour at Hedeby/Haithabu.
What has survived showed that it was a wooden core overlaid with two layers of leather, with diamond shaped cutouts in the upper layer and with copper alloy rivets or pins along the edges of the cutouts. No evidence of dye colours survived although one is thought to have been darker than the other.
So, here it is. Birch cored, fleece lined, one layer of leather dyed with the very last of my Libyan kermes, the upper layer is oak tanned stained with walnut.
I went with a Cronk Moar style suspension because it can be used without resorting to any slide, bridge or other elements (no suspension method was apparent on the remains).
 Attachment: 146.28 KB
 Attachment: 218.98 KB
Kai Lawson
PostPosted: Thu 02 May, 2013 7:12 pm    Post subject:         Reply with quote
I like the Hedeby/Haithabu interpretation. Rather elegant in its simplicity, but looks quite good, and also isn't something you see every day. I take it that there were no metallic components found or evidence of them, aside from the rivets?
"And they crossed swords."
Matthew Bunker
PostPosted: Thu 02 May, 2013 10:26 pm    Post subject:         Reply with quote
Correct.
Adam Simmonds
PostPosted: Fri 03 May, 2013 3:39 am    Post subject: Scabbard makers in London UK         Reply with quote
Hello all,
Apologies if this is slightly off topic but does anybody know of a good scabbard maker in London?
I recently acquired a lovely little sword from the late 17th Century at the biannual Arms Fair in Earls Court and I would like to have a scabbard made for it.
Best regards,
Adam
Page 2 of 5 Reply to topic
Go to page Previous  1, 2, 3, 4, 5  Next All times are GMT - 8 Hours
