Lancelot Chan
Posted: Mon 30 May, 2005 12:33 am Post subject: Hardness of some major brand swords |
I've received my pack of flexbar hardness testing files today and did the test for the following swords at my home. Here are the results:
My tinker : above 50 below 55 HRC (2001 model, forte)
Atrim short sword : above 50 below 55 HRC (forte)
Albion Brescia Spadona : 40 to 45 HRC, seems closer to 40 though at forte, 55 HRC at the edge 4 inches from the tip
Fred Chen 1050 Carp Jian : above 50 below 55 HRC (forte)
Paul Chen Pudao: above 50 below 55 HRC, seems closer to 50 though (forte)
Arms and Armors German Bastard Sword : 45 to 50 HRC (forte)
Lung Chuan consignment swords ( http://www.rsw.com.hk/so5.htm ) : below 40 HRC (forte)
Last edited by Lancelot Chan on Mon 30 May, 2005 10:18 pm; edited 2 times in total
Kenneth Enroth
Posted: Mon 30 May, 2005 12:52 am Post subject: |
The Albion is pretty soft. It wouldn't hurt to increase the hardness a few points.
Posted: Mon 30 May, 2005 12:52 am Post subject: Re: Hardness of some major brand swords |
| Lancelot Chan wrote: | | Albion Brescia Spadona : 40 to 45 HRC, seems closer to 40 though |
That's softer than I'd want it. I wasn't able to find a place on Albion's site that specs this out, but I'd imagine they're shooting for 45+ RC. Assuming you're accurate, I'd say the combination of the low hardness with your over-sharpened (compared to Albion's standard) edge, I'd say somebody royally screwed up your particular Brescia. I still maintain that that particular model is wrong for your needs, but you'd have to agree that it would be nice to verify that your sword is a good example of how that model is intended to leave the shop. Hardness isn't everything, and accurately measuring it with files is difficult and very localized to the area measured (the extreme edge), but it will be interesting to have Albion respond with an explanation of the intended hardness range for their weapons. At least, that would be interesting to me.
It's worth noting that your measured results for the other American makers are fairly consistent with what they publish for their wares.
Kenneth Enroth
Posted: Mon 30 May, 2005 1:08 am Post subject: Re: Hardness of some major brand swords |
| Nathan Robinson wrote: | | Lancelot Chan wrote: | | Albion Brescia Spadona : 40 to 45 HRC, seems closer to 40 though |
That's softer than I'd want it. I wasn't able to find a place on Albion's site that specs this out, but I'd imagine they're shooting for 45+ RC. Assuming you're accurate, I'd say the combination of the low hardness with your over-sharpened (compared to Albion's standard) edge, I'd say somebody royally screwed up your particular Brescia. |
Did the sword have a sharper than normal edge or not? I read that claim on SFI but Lance refuted that he had requested a sharper edge and then the thread was locked.
Posted: Mon 30 May, 2005 1:11 am Post subject: Re: Hardness of some major brand swords |
| Kenneth Enroth wrote: | | Did the sword have a sharper than normal edge or not? I read that claim on SFI but Lance refuted that he had requested a sharper edge and then the thread was locked. |
Yes, Kenneth. I just said that. And if you read the SFI topic, you'll see that the edge on Lance's sword was sharper than Albion's standard model. No. Lance didn't request a non-standard edge.
Lancelot Chan
Posted: Mon 30 May, 2005 1:15 am Post subject: |
Nathan was right that I didn't ask for a sharper edge than original.
BTW, since the test require a small surface, it couldn't be done RIGHT on the edge line. I did it as close to the edge as possible, though. For example, in the Spadona's case, I did it along the secondary bevel area it has. Also double checked on the flat side too. Not big difference. (can't notice any difference... and ended up scratching my sword a larger area hahha)
Yet, to minimize the scratches' visible effects, I did these hardness test on the forte area, not at the tip of the sword. But I dun think an unhardened tang would mean an unhardened forte either. I avoid doing this too close to the cross guard either just to be fair.
Kenneth Enroth
Posted: Mon 30 May, 2005 1:36 am Post subject: Re: Hardness of some major brand swords |
| Nathan Robinson wrote: | | Kenneth Enroth wrote: | | Did the sword have a sharper than normal edge or not? I read that claim on SFI but Lance refuted that he had requested a sharper edge and then the thread was locked. |
Yes, Kenneth. I just said that. And if you read the SFI topic, you'll see that the edge on Lance's sword was sharper than Albion's standard model. No. Lance didn't request a non-standard edge. |
I rered the thread and it would be best to get clarification from Albion if Lance's Brescia has a sharper edge and why it was applied since he hadn't requested it?
Thomas McDonald
myArmoury Alumni
Posted: Mon 30 May, 2005 4:32 am Post subject: |
Thanks for your report, Lance !
The interesting thing about your Bresia reading is that it's probably spot on to the originals rc !
Mac
XX ANDRIA XX FARARA XX
Mac's PictureTrail
Michael Pearce
Posted: Mon 30 May, 2005 7:05 am Post subject: |
HRc40-45 is spot on in the 'average' hardness range for the (relatively few) medieval swords that have been tested to the best of my knowledge. One cannot fault Albion if this is the intended hardness done in the interestss of historical accuracy. However this makes it somewhat unsuited to Mr.Chan's- and perhaps other customer's needs. If this is deliberate it would be a good idea for Albion's marketing to reflect this so that furure customers with needs similar to Mr.Chans will not be disssapointed.
Michael 'Tinker' Pearce
Lancelot Chan
Angus Trim
Posted: Mon 30 May, 2005 8:29 am Post subject: |
| Thomas McDonald wrote: | Thanks for your report, Lance !
Mac |
Hi Mac
I don't know that the original has been tested, and without knowing, I think its a dangerous guess of where the hardness might be, or how uniform it might be......
I've had a couple of conversations with the renowned Craig Johnson on this, and the average, is just that an average. Tested meaurements run from the mid 30's rc, to the mid 50's rc. Earlier in the year, there were two conversations that touched on this, one on SFI, and one here.....Craig was a part of both of them.......
swords are fun
Posted: Mon 30 May, 2005 9:36 am Post subject: |
From collecting mostly modern folding knives and fighters I was used to consider 55rc as minimal acceptable hardness and 58rc to 60rc as " normal " .
I have now gotten used to the idea that swords around 50rc is both historically correct and a better balance between hardness and flexibility: Now low 40rc and 30rc seem rather " SOFT "
Now the hardness scale may not be very linear as in 25rc is half as hard as 50rc. ( I just don't know ???? )
What is the harness of dead soft un-heatreated 1075 ?
I assume from other posts that there is more difference between a dead soft blade and 40rc than there is berween 50rc and 58rc.
So how soft is SOFT, 30rc to 40rc ???
Now I can see that for reasons of historical accuracy many collectors would want swords to have a hardness the same as that of an original. Personally I like having the sword look exactly like the historical one it is duplicating but wouldn't mind having it harder if harder, within reason, made it a better sword. Hey, if it could be made of " UNOBTAMIUN " that would cut diamonds like butter, would never need sharpening, and could support the weight of an M1 Abrams tank without bending more than an inch I wouldn't mind that at all.
Well if Lancelot's sword has a softer than Albion SPECIFICATIONS for this sword + being ground with a finer edge than standard ( Honest mistake there. ) I think a replacement sword should at least be considered.
For the use Lancelot intended this may not be the ideal sword considering the cost. ( Unless he is O.K. with the fact that frequent use will do some damage to the sword, as we have already discussed too much already. )
Angus Trim
Posted: Mon 30 May, 2005 9:55 am Post subject: |
| Jean Thibodeau wrote: |
I shouldn't answer for Albion, but when experimenting with 1065 and 1075 in the past, I had it subannealed before machining. It then tested 18 to 20 rc on the C scale {the most commonly used scale, of which we're talking now}. This low, the C scale is considered inaccurate, but it should give you an idea......
The 5160 I work with is also subannealed, to the same level......The subannealing is more important though for its stress relief properties, and making the material more consistent, than the actual reduction in hardness.
swords are fun
Thomas Hoogendam
Posted: Mon 30 May, 2005 10:16 am Post subject: |
Oke guys, this is making me a bit un-easy. I was planning on ordering an Albion Knight. But after reading this, I'm getting a bit ancious.
Joe Fults
Posted: Mon 30 May, 2005 10:56 am Post subject: |
Intersting stuff in this discussion. I commend Lance for taking this initiative. Now we need to be patient since all specualtion right now is based on a sample of 1, with no word from the maker whether the subject sword is representative of what they are trying to achieve.
*edit to fix spelling.
G. Scott H.
Posted: Mon 30 May, 2005 11:03 am Post subject: |
All we can do is speculate, until somebody from Albion chimes in. Interesting to note the hardness of the Chen Pudao. There's been some complaint in the past about the padao and it's shorter brother, the dadao, being too soft. I woudn't call 50+RC "too soft." The dadao and pudao are some of the few Asian weapons that really interest me, and that I've considered buying, so this is good news. Thanks, Lance!
Posted: Mon 30 May, 2005 11:04 am Post subject: |
| Joe Fults wrote: | | Intersting stuff in this discussion. I commend Lance for taking this initiative. Nowwe need to be patient since all specualtion right now is based ona sample of 1, with no word from the maker whether the subject sword is representative of what they are trying to achieve. |
Exactly! Thank you, Joe. This goes to that all-important word: context.
Michael Pearce
'As rolled' 5160 SS is considered 'half-hard' and typically arrives at my shop with a hardness of approximately HRc 23-35. Gus's sub-anneal reduces this and stress relieves the steel- not necessary for me as our processes differ. 'Dead-soft' 1075 is likely to be in the HRc13-18 range- but as Gus specified, the machines used to test on the Rockwell scale become less accurate below a certain threshold hardness.
Thomas- I would not worry too much as yet- this is after all only one sword. Heat treatment of swords is tricky, and there have been no other substantiated claims of softness of thier swords. It could be an isolated incident. If you are nervous simply ask Albion to determine the blades hardness or simply agree to accept the return of the sword or to replace it under warranty if it is found to be too soft. Given Albion's record for customer service I doubt this will be a problem.
Kenneth Enroth
Posted: Mon 30 May, 2005 12:19 pm Post subject: |
If the historically accurate hardness ranges from the mid 30's to the mid 50's IMO modern swords should be in the upper range, not the lower.
