Elnathan Barnett
Posted: Wed 21 Nov, 2007 7:14 am Post subject: |
Benjamin,
In Basel,1605, they were shooting at a 30" mark at 190 yards with smoothbores braced on the cheeks (no shoulder stocks). Target guns, not military, but worth noting all the same. Even if you cut that down to a third, yoou are still looking at approximately a hundred yard capability.
I don't recall if William Rogers mentions accuracy, but he is quoted a couple of times in Robert Held's Age of Firearms and was a fervent supporter of firearms. You might check him out.
edited:
190 yards, not 290. mea culpa...
Last edited by Elnathan Barnett on Wed 21 Nov, 2007 9:55 am; edited 1 time in total
Peter Bosman
Posted: Wed 21 Nov, 2007 7:16 am Post subject: |
Benjamin H. Abbott wrote: | I can believe early guns were more accurate than they've been given credit for, but I serious doubt they were significantly more accurate than bows, at least in the sixteenth century. |
I think it is safe to state that the composite recurve was more accurate over greater range than rifles untill well into the 20th and that automatic fire arms first achieved a functional advantage over this bow.
The bow has two distinct disadvantages compair to fire arms;
- it cannot be carried ready to fire
- it needs a lót more skill to be sort of accurate
For large scale warfare one can add the greater complication of manufacture.
Back to the original question it is fairly simple to compair fire pówer.
Composite recurves are VERY powerfull and it is mainly the distortion of the soft lead that makes a bullet so damaging to a human body. Use a steel bullet and it will not differ much from an arrow or a smallsword. It will simply pass through say a biceps whereas an inperfect slug of soft lead will rip the arm off.
So, there you have it. The fire arm requiered relatively little skill to be very effective and was relatively easy to produce.
peter
Posted: Wed 21 Nov, 2007 8:20 am Post subject: |
Peter Bosman wrote: | Benjamin H. Abbott wrote: | I can believe early guns were more accurate than they've been given credit for, but I serious doubt they were significantly more accurate than bows, at least in the sixteenth century. |
peter |
And as stated before firearms have more armour piercing capability than arrows or crossbow bolts.
Up to the mid 19th century good archery could have been very effective in combination with firearms in a tactical sense. The cultural changes and the lack of skilled archers making it impractical at least in Europe. ( Historical fact as opposed to theoretical advantages ).
In the East many cultures from the Turks to the Japanese combined both weapons.
If one could combine 18th century musketery/field artillery with 14th century English longbowmen and men-at -arms one could come up with some interesting tactical ideas: At least as a thought experiment.
Lin Robinson
Posted: Wed 21 Nov, 2007 8:49 am Post subject: |
peter |
Peter I am going to strongly disagree with this statement. As support for my disagreement I will direct your attention to the Creedmoor rifle matches between the US and Irish teams in 1874. This match was shot at ranges of 800, 900 and 1000 yards. The Irish team used Rigby muzzle loading rifles. The US team used Sharps and Remington Rolling Block breechloaders. The targets shot had a square bullseye of 3 feet by 3 feet. The "center" of the target, which contained the bullseye, was 6 feet by 6 feet square. The "outer" scoring areas - two on each side of the "center", were 3 feet wide by 6 feet high.
I won't bore you with the individual scores for both teams, but the final target for the Americans, shot by a man named H. Fuller, scored 171 out of a possible 180 points. He got 36 bullseyes and 9 centers, at 1000 yards. No misses. This target won the match for the Americans.
I do not believe that any recurve bow can fire an arrow that far in the first place. Even at ranges where the recurve can hit the target, these riflemen could clearly produce better scores than any bowman. Furthermore, there were thousands, perhaps hundreds of thousands, of men and women in the US during the 19th c. who could have outshot a recurve bow.
Lin Robinson
Posted: Wed 21 Nov, 2007 9:30 am Post subject: |
Lin Robinson wrote: | Peter Bosman wrote: |
peter |
I do not believe that any recurve bow can fire an arrow that far in the first place. Even at ranges where the recurve can hit the target, these riflemen could clearly produce better scores than any bowman. Furthermore, there were thousands, perhaps hundreds of thousands, of men and women in the US during the 19th c. who could have outshot a recurve bow. |
Oh, I completely agree here and the bow has only a clear advantage in mass volley volumes rapid rates of " firing/loosing "
Close range accuracy and against un-armoured 18th century troops would be a nasty surprise at least the first few times and force the use of armour. ( As mentioned in an early post on this thread ).
There is a rock, paper, scissors relationship here:
1) Armour seriously degrades the effectiveness of arrows.
2) Firearms makes most armour ineffective.
3) Arrows being a serious threat to unarmoured troops force the wearing of armour in spite of the above ( musket ).
Pre-metallic cartridge firearms being slow to load and inaccurate in muskets ( relatively inaccurate ).
Also the great accuracy possible for rifled black power guns makes them even slower to load than the musket ( generalization ).
Bows: High rate of fire, good accuracy under 100 yards but dependent on high skill level.
So my conclusions: On a theoretical battlefield using muskets, rifles, bows.
1) The rifles are specialist sniper weapons.
2) The muskets are your volume of fire weapon and kill in spite of armour.
3) If bows are in the mix armour has to be worn or the fast rate of fire of archery will be very deadly since each arrow on target will wound or kill as opposed to a high percentage of arrows boucing of the armour.
If both sides use the 3 weapons + armour the archery is of limited use.
If one side is a typical un-armoured 18th century force the archery of the other side could butcher the un-armoured troops.
Sorry for the redundancy of the above: I'm just trying to cover all the possibilities and interactions between the weapons systems. Anything I missed or got wrong ?
Again bottom line: The historical reality is obviously different for all sorts of reasons from social organization, to logistics to the lack of skilled archers etc ....
Posted: Wed 21 Nov, 2007 9:52 am Post subject: |
I am not at all disagreeing with the rock paper scissor analysis above. I think it definitely fits the 16th-17th century European war environment.
In the case of Hernando De Soto in the Southeast America, his European forces started out with breast plates, some mail, helms, some greaves, etc. The interpretations of three surviving accounts indicate that the unarmored "indians" did pretty well at at playing sniper with their bows, putting arrows through gaps in armour, eyes, throat, etc. by using guerrilla warfare style tactics at close range with their bows (night raids, ambushing along trails, and even surprise raids into fortified encampments.)
This does not really seem to fit the expected conditions (behavior or terrain) for European warfare, and could have turned out much differently without the type of dense vegetation that was a factor in Desoto's gradual loss of numbers. I suspect it is only fair and reasonable to consider the bow as potentially effective against forces with historical armour when appropriate conditions, skills, and tactics are employed.
Elnathan Barnett
Posted: Wed 21 Nov, 2007 9:54 am Post subject: |
Another thing that hasn't been sufficiently addressed on this thread is the pairing of arrows to bows. Due to the archer's paradox, the flexibility of arrows -"spine" - is important to accuracy - a bow of a given weight must be paired to a particular degree of flexibility, and the flexibility of the arrows must be consistent within a batch OR the archer must be familiar enough with his arrows that he can compensate for differences. The same is true with weight of both arrow shaft and head- either consistency or experience with a particular arrow is necessary for accuracy.
Now, I believe I read somewhere that during the 100 Years War arrows were made to a particular length (a clothyard?) and cut down after being issued, with the heads stuck on with wax. Now, I have no doubt that medieval fletchers were a skilled lot, but somehow I doubt that arrows made to generic spine and weight, then cut down in the field and fitted with heads which may not have been made to very tight specifications are going to either match a given bow very well or be very consistent, especially since a war arrow is going to be essentially a disposable object.
All of which to say, the carefully matched and cared-for arrows used by modern archers are going to show a much higher degree of accuracy than are medieval or rennaissance war arrows. If you are going to compare "sniper-quality" (for lack of a better term) archery to firearm, it is only fair to compare them to the equivalent, which would be either a contemporary rifle or the smoothbore match guns mentioned in my earlier post.
Incidently, during the 18th century muskets often fired multiple projectiles - the buck-and-ball load was the standard for the Continental Army during the American Revolution. Does anyone know if this was doen during the 15th and 17th centuries?
Benjamin H. Abbott
Posted: Wed 21 Nov, 2007 10:24 am Post subject: |
Quote: | I don't recall if William Rogers mentions accuracy, but he is quoted a couple of times in Robert Held's Age of Firearms and was a fervent supporter of firearms. You might check him out. |
William Rogers? Do you mean Sir Roger Williams? If so, I've read his work a number of times. He considered guns superior for various reasons. Greater accuracy wasn't one of them.
Quote: | In the case of Hernando De Soto in the Southeast America, his European forces started out with breast plates, some mail, helms, some greaves, etc. The interpretations of three surviving accounts indicate that the unarmored "indians" did pretty well at at playing sniper with their bows, putting arrows through gaps in armour, eyes, throat, etc. by using guerrilla warfare style tactics at close range with their bows (night raids, ambushing along trails, and even surprise raids into fortified encampments.) |
Yes, and some accounts suggest armor wasn't even much use against Amerindian arrows. Cabeza de Vaca wrote of men wounded by arrows despite their good armor. He claimed Amerindian arrows could drive six inches into a poplar tree and transfix an oak the size of a man's calf. Somewhat similarly, de la Vega gave many examples of arrows piercing mail. However, the Spanish fought back with bows and crossbows of their own and with horses. De la Vega has a Spaniard with a crossbow winning an archery duel with an Amerindian. The Spaniard struck the Amerindian in the chest and received only a minor neck wound in return.
Last edited by Benjamin H. Abbott on Wed 21 Nov, 2007 1:17 pm; edited 1 time in total
Randall Moffett
Posted: Wed 21 Nov, 2007 11:19 am Post subject: |
Elnathan,
I think you may be off a bit on a few points.
Archers paradox ends basically after a few meters when the spine will then go more or less straight. That said it does not seem to need huge compensation as it does so naturally once it stops. The Royal Military College has slow motion footage and it shows the distance needed for it to slow the flex in the spine from the paradox.
The types of bows used as warbows for war at this time could/would be able to be very accurate with arrows of a fair variety of weights. My guess is they would vary only a few grams and that they used various arrows for various tasks so this would seem to be just part of the job. Once more, likely the distance over accuracy suffers with very overly heavy arrows but the draw weight of the bow is hugely related for this as well.
Arrows were made to a standard size... yep, I agree. Regardless the arrow's length does not seem to drastically affect the accuracy as it does the extra dead weight of the arrow before the bow. This would limit the distance achieved not accuracy. That said a decent archer could fit his own arrows to his bow with little problem I'd assume. Apart from the heads and the shafts the rest can be done in the field but I do not think it related to accuracy as much as other factors.
Elnathan Barnett
Posted: Wed 21 Nov, 2007 3:16 pm Post subject: |
Benjamin,
yes, that is who I was thinking of. I don't have the book mentioned so I wasn't sure what exactly he said, but I thought I'd mention it.
Randall,
An arrow that doesn't have the proper spine wouldn't stabilize properly, ergo its not going to be accurate. Properly matched, yes, it will stabilize a few yards from the bow. Too flexible or too stiff it will fishtail around, I believe. How sensitive the higher draw-weights are to variations in spine I don't know. Trying to match arrows to bows sounds like a logistical nightmare to me, so I expect that arrows were made to a "on-size-fits-all-within-standard-warbow-draw-weight-ranges," and archers shot what they were issued. Probably arrows were issued on a group basis, so an archer might be able to pick through the pile get at least a few that "felt right," but closer matching than that doesn't sound very plausible, nor is the suggestion that could shoot their arrows a couple of times to get the feel for them before firing them in battle.
As for weight, is the variations that would kill accuracy. Even starting with a uniform arrow, cutting them down in the field and fitting them with heads that also vary in weight is going to introduce greater variations. It is the cumulative errors that are the problem.
Here is a question: What is the accuracy of bows? I don't recall anyone giving figures, though I may have missed them.
Second, why does everyone assume that guns are cheaper than bows? Even a matchlock mechanism requires some precise geometry to function smoothly, while making a barrel, like forging a swordblade, requires a great deal of time and skill to forge, bore, and breech, not to mention a large quantity of high-quality iron (it takes about 22 pounds of iron to make a 6-8 pound barrel, according to Foxfore 5). Even the stock requires a bit of time and skill to make. I know bows are fiddly things to make, but still...
Posted: Wed 21 Nov, 2007 4:45 pm Post subject: |
Just a thought but an archer might use standardized supply train arrows for general work i.e. Un-aimed volleys at medium to long range, and elite archers might have a few selected and tuned to their bow arrows for those times when high accuracy was needed ?
Would arrows come in all the same weights/spine or in a range of light, medium and heavy spines to match the average bows that might vary in draw weight but still all heavy bows: 100 pound draw to 180 pound draw with the average being somewhere between ?
Jack W. Englund
Posted: Wed 21 Nov, 2007 7:00 pm Post subject: |
Gentlemen/ I think we need to step back a moment & set our parameter's. We seem, in IMHO, to be discussing 2 different things,. The English/Welsh Long bow & the war bows used by native Americans.( N. & S) IMHO, these weapons are VASTLY different , not only in construction, BUT MOST IMPORTANTLY USAGE !!
Disclaimer- I am Not an expert i either areas ( I do own & shoot in competition, N. Amer. style bows ( flat bows, & a variety of arrows associated (historically) with them. But my knowledge of the "long bow IMHO ) the predominate"war bow" of it's day, is strictly through cursory historical study.
Long bow -Basic tactical usage etc:
1. Mass firing @ troop concentration ( the artillery of the day) 10-20 arrows per min.
NOTE- relatively lg.# of archers (100s- 1,000s)
2. Mass & more accurate firing @ closer range ( see above
3. Arrow woods
a. aspen,poplar,elder,birch,& willow for "flight arrows (distance)
b.Ash, hornbeam,& oak for penatration.
c. fletching - feathers, goose, peacock, swan.
NOTE- the arrows used, (with the right heads - bodkin) could & did penetrate both chain & plate Armour.)
5.. "When up close & personal" they fell back behind the "pole arms
NOTE the long bow was made primary of yew and a pull of over 100#s ( not all agree) & was 5-6' in length ,with a "killing" range of appox. 250 yd.
arrows were made "true"
Native Amer. bow tactical usage, etc :
1. en masse firring was not the norm. native tribes were small & warfare was basically limited to small groups.
2. Bows varied VASTLY
a. Most bows were "flat bows (there were some recurves, but few.) Some laminates (bone, mostly snake skin)
b.Bows were made out of avail. material. (ranging from will to elm, ash,, hickory,oak, with the best (IMHO) from "osage orange"
c.Arrow shafts varied greatly in truness
d., points ranged from fire hardened wood to Bone & stone ( the best in MHO was obsidian)
e. What ever available
NOTES- The following is based on the "best :
1. Pull wt. under 60#s
2.Could not penetrate Armour.
3. Max killing range = 100yds (most effective under 50 yd)
4.Accuracy- 50 yds & under = good 50yds+ = moderate
Conclution = ( IMHO ) In thr area of the use of the bow pnThe Battle fields of EUROPE MUST be looked @ seperately
Jack
Benjamin H. Abbott
Posted: Wed 21 Nov, 2007 8:43 pm Post subject: |
I can't agree with much of that, Jack. Yes, Amerindians tended to use their bows differently than the English. However, a bow is a bow. Obviously, it depends on which Amerindian group you mean. Some may have used light bows, especially for hunting. However, all accounts agree that the Amerindians of Florida used extremely long and powerful bows. I mentioned examples from Cabeza de Vaca in an earlier post. By the way, he wrote that Amerindian archers struck with unerring accuracy out to 200 paces.
The Spaniards made no distinction between these weapons and those of the English. De la Vega wrote how de Soto's band included an Englishmen and Spaniard who'd been raised in England. Unlike the rest, these two used bows proficiently. De la Vega also wrote that none of the Spaniards could fully draw a captured Amerindian bow. Whether this included the two archers is unclear. Either way, it's a testament to the strength of Amerindian bows.
Stephen Hand
Stephen Hand
Posted: Wed 21 Nov, 2007 11:41 pm Post subject: |
Peter Bosman wrote: | I think it is safe to state that the composite recurve was more accurate over greater range than rifles untill well into the 20th and that automatic fire arms first achieved a functional advantage over this bow. |
I find this statement astounding. At the battle of Omdurman in 1898 the British commenced aimed fire with their Lee Metford rifles at 2000 yards. No Dervish came within 300 yards of the British perimeter, or in other words all of the Dervishes were killed before they entered maximum arrow range.
Stephen Hand
Editor, Spada, Spada II
Stoccata School of Defence
Stephen Hand
Benjamin H. Abbott
Posted: Thu 22 Nov, 2007 7:23 am Post subject: |
Quote: | I'm not aware of any claims from the 15th-17th centuries about whether bows or muskets were more accurate. |
Here's a bit I saved from Smythe on the inaccuracy of guns. He wrote a lot more than this on the subject:
If Harquebuziers alfo or Mofquettiers in taking their fights, doo faile but the length of wheate corne in the heighth of their point and blancke, they work no effect at the marks that they fhoote at, although they bee verie great; and in cafe they doo take their fights at iuft poynt & blanke, yet by reafon that their bullets are lower by boares than the heighth of their peeces, the faid bullets doo naturallie mount, and flie vncertainlie and wide from the marke or markes that they are fhot at, and the further in diftance the more they faile.
I don't know if he wrote it explicitly, but the clear implication was that bows were more accurate. Writing years earlier, Fourquevaux seems to have thought about the same thing:
Amongft other weapons leaft accuffomed, are the Bowe and the Croffebowe, which are two weapons that may do very good feruice against vnarmed men, or thofe that are ill armed, fpecially in wet weather, when the Harquebufier lofeth his feafon. And were it fo that the archers and croffebow men could carry about them their prouifion for their bowes and crossebowes, as eafily as y Harquebufiers may do theirs for their Harquebuffes I would commend them before the Harquebuffe, as well for their readineffe in fhooting, which is mutch more quicker, as alfo for the fureneffe of their fhot, which is almost never in vayne. And although the Harquebufier may fhoote further, notwithftanding the Archer and Croffebow man will kill a C, or CC, pafes off, afwell as the Harquebufier: and fometime the harneffe, except it be the better, can not hold out: and the vttermoft the remedy is that they fhould be brought as neere before they do fhoote as poffibly they may, and if it were fo handled, there would be more flaine by their fhot, then by twice as many Harquebufiers, and this I will prooue by one Croffebow man that was in Thurin, when as the Lord Marfhall of Annibault was Gouernour there, who, as I haue vnderftood, in fiue or fixe fkirmifhes, did kill and hurt more of our enemyes, then fiue or fixe of the beft Harquebufiers did, during the whole time of the fiege.
Shayan G
Posted: Thu 22 Nov, 2007 7:49 am Post subject: |
Just a quick aside, since it's Thanksgiving and I'm not going to be delving into any citations today--
Many Mongolian, Turkic, and Persian accounts speak of accuracy much farther than 100 yards with composite bows. These soldiers started training almost from birth, and trained daily for their entire lives, honing their skills regularly in competition and combat. I wouldn't assume too quickly to the early musket's superiority to the bow in terms of accuracy simply because of later technological advantage--in these warriors' hands, it was capable of quite astounding things. This, in fact, is one of the reasons Central Asia was so slow to adopt firearms--until the advent of the mass-produced and rifled musket, it would have been a step backwards in terms of efficiency.
Back to the cooking--HAPPY THANKSGIVING!!
Posted: Thu 22 Nov, 2007 7:51 am Post subject: |
Accuracy ? Depends on what we are comparing:
1) Musket using undersized ball to speed loading fired in volleys, the accuracy would be poor if aimed at a single target, assuming that the musket even had a front site.
2) Musket with a strait bore and a tight fitting ball and a competent skilled shooter: Accuracy would be adequate to 100 yards to 200 yards on single targets. ( Not a hit every time but close enough to make the target nervous. ).
3) Muzzle loading rifle with good sights, the optimum load for the gun and a very good shooter: We can get to very long accurate ranges as other posters have already shown.
Archery, bows & crossbows, with good quality archers should be better in the accuracy department than (1) with (2) to close to call under 100 yards +/- 25 yards But (3) would have much better accuracy and range.
This is just a ballpark guess from me and the quality of weapon/shooter variable makes for an overlapping range of results.
Randall Moffett
Posted: Thu 22 Nov, 2007 8:22 am Post subject: |
In medieval texts distance accuracy with longbows are listed as important. The butts are about man height and perhaps twice as wide maybe a bit wider for practice they seems at a minimum to use 220 and even 260 yards for target shooting of this nature. This indicates a man sized target could still be hit from quite far away, at the time it would be one of a very limited number of things that could.
Jean,
I think your summary is pretty good to me.
Elnathan,
I had wrote up a fairly large post to answer some of the statements you made but it ate it and I am not typing it again, sorry but not feeling too well.
First thing. You need to see gents that can shoot these real warbows. You will find they use a wide variety of arrows of various shaped heads, shafts and multiple weight employed with the same bows. accuracy may be a factor but any simple archer can figure out how to gauge it well.
Weight is a variable in using the bow. No doubt about it. The variation in the arrows weight does not seem to be significant enough to make them have difficulty with aiming arrows unless they are tree trunks or something. Between the gents I know who shoot heavy weight bows some use 90 some 150, they all can shoot off arrows of various weights on their bows with distance being harder to achieve after a point due to heavier arrows but all need be over a certain weight to avoid shattering. I suppose the heavy arrows might not be 'accurate' at over long distance but that is assuming the medieval archer used the same arrow for all tasks. The kings ministers ordered multiple typed arrows which the close and patent rolls and the early modern ship the Mary Rose indicate was established and understood then but perhaps today not so well. The archer would be expected to use various arrows for various jobs, distances, etc. It seems likely that the more militarily active semi-pro archers would likely be the better at this target/sniping shooting than the common levied man, which makes sense. The reason bows are useful is in the thousands for volley fire at a mass of other men. That said specialty arrows would not be uncommon. Retinues almost always bring chests of arrows along for their own use. Even levied archers were required to provide 2 sheaves most of the late medieval period. That said with the one or two most common type of arrows the king orders gathered for his armies and likely used by the bulk of troops I assume most would be used in mass volleys so individual aim would be not as imperative. If you have some good hands on experience with this or something that can show that weight directly relates to accuracy I'd be interested in it though.
