Posted: Mon 07 Jun, 2010 11:47 pm Post subject: |
Why use butted maille in preference to riveted maille could be the question since everything else being equal riveted will always be harder to pierce than butted of the same diameter and wire gauge and better in most cases than any butted maille. ( Unless of ridicoulously heavy gauge and very small diameter, which Japanese maille was not ).
Japanese/European doesn't change the physics that an open ring than be forced open much more easily than a riveted one or even a modern welded ring: To burst a welded/riveted/solid ring the ring must be deformed enough for it to break or be cut while a butted ring is very easy to wedge open.
Is butted completely useless: No when dealing with draw cuts but yes against a thrust with anything reasonably pointy !
Why did the Japanese use mostly butted rings and why could they be still useful ?
A) Tempered and butted wire can be reasonably strong.
B) Rings that connect like key rings with multiple turns and also spring tempered might be close in strength to riveted maille.
C) Butted rings used to connect plates or for non vital areas.
D) Earlier styles or purely Japanese styles of maille before contacts with European mail seemed to have been mostly butted, so the tradition of using it would have continued even if it was less effective than riveted.
When riveted maille was imported or at least known about in Japan how popular did it become ? Did it replace butted maille for all uses or did it become of general use when the armour was primarily all maille ?
From the pics shown it seems that some very expensive maille was made of butted rings ? Maybe it was considered sufficient for whatever purposes maille would have been preferred by the Japanese and when stronger armour was desired they would have used their more effective traditional alternatives.
In any case just speculation on my part and questions worth asking, but I see no need to get all " emotional " about it instead of just exchanging ideas, opinions or supported by evidence facts, and polite rebutals.
( EDITED: Cross posted the above before seeing Nathan's comment as I was writing it before he posted ).
Jean Henri Chandler
Posted: Tue 08 Jun, 2010 7:42 am Post subject: |
Brawn Barber wrote: | We've done extensive testing on piercing attacks against both butted and riveted maille. Although they were both backed with leather (as a blunt additional defense) the butted maille greatly helped the slashing attacks but failed miserably against a stanch piercing attack. The riveted maille, although occasionally permitting a separation of a ring or two was much superior in preventing a piercing attack than the butted mail. In cases where penetration of the butted maille presented a 3" breach, the riveted maille yielded only about 1/16". The tests were performed with 8mm ID rings and both 7/8 oz and 13/15 oz leather. |
Are any of these tests published or posted online somewhere? I'd be interested to see them.
J
Jean Henri Chandler
Posted: Tue 08 Jun, 2010 7:44 am Post subject: |
Jojo Zerach wrote: | Is the image of the Samurai a photograph? I thought it was a painting of some sort, due to the colors. Though the grass at the bottom does indeed look out of focus. |
Yes it's a photograph from the 1880s I believe, the colors are added later with a wash (painted on) this was common in the late 19th / early 20th Century.
J
Brawn Barber
Posted: Tue 08 Jun, 2010 9:23 am Post subject: |
Jean Henri Chandler wrote: | Brawn Barber wrote: | We've done extensive testing on piercing attacks against both butted and riveted maille. Although they were both backed with leather (as a blunt additional defense) the butted maille greatly helped the slashing attacks but failed miserably against a stanch piercing attack. The riveted maille, although occasionally permitting a separation of a ring or two was much superior in preventing a piercing attack than the butted mail. In cases where penetration of the butted maille presented a 3" breach, the riveted maille yielded only about 1/16". The tests were performed with 8mm ID rings and both 7/8 oz and 13/15 oz leather. |
J |
http://schmitthenner.com/Armor_Tests.htm
Admittedly, the quality of these clips are less than stellar, however I will clarify if there's any questions. I've been having some problems with uploading more videos lately so I haven't had a chance to upgrade them yet.
Didn't document slashing tests regarding butted or riveted maille as I wanted to portray the likely weakness in maille(separation of the links).
Eric S
Posted: Tue 08 Jun, 2010 11:50 am Post subject: |
Jean Thibodeau wrote: | Why use butted maille in preference to riveted maille could be the question since everything else being equal riveted will always be harder to pierce than butted of the same diameter and wire gauge and better in most cases than any butted maille. ( Unless of ridicoulously heavy gauge and very small diameter, which Japanese maille was not ).
( EDITED: Cross posted the above before seeing Nathan's comment as I was writing it before he posted ). | Jean, you bring up some good points. For anyone who is actually interested in various types of chain armor, the Japanese provide a great opportunity to study it as there are large amounts of different types of patterns available for sale at fairly low prices compared tp Eastern or European chain armor. Although all Japanese chain armor available appears to be butted at least partially it is still an interesting study. The Japanese were thought to have adopted the European 4 in 1 pattern in the 1500s and added it to the standard Japanese patterns but....did they take the pattern from riveted European chain armor and just produce it in a butted style or did they observe butted European 4 in 1 and copy it exactly? I do not know enough about European chain armor to know if the armor the Portuguese first brought to Japan could have been butted...maybe someone here has an answer...I am assuming that the Japanese first saw riveted European chain armor and tried making it and decided for various reasons to just stick with butted chain while using the pattern, unless it is common knowledge that the Portuguese actually used butted mail at that time (1540s) The older Japanese patterns were lighter in weight than the and have more open space between the links than the European pattern and they readily adopted its use while still using their older style patterns on some armor...sometimes even mixing the two patterns...the heavy pattern European 4 in 1 for the torso and the lighter Japanese 4 in 1 on the lower areas. Here is an example of a chain jacket or kusari katabira with a heavy pattern covering the torso and the Japanese twisted link 4 in 1 on the lower panels.......
Jean Henri Chandler
Posted: Tue 08 Jun, 2010 12:03 pm Post subject: |
I don't know of any European armor from this period which was butted. In fact I'm not aware of any European mail dating to before 1800 AD which was butted, (perhaps someone can correct me if I'm wrong).
Therefore even if the Japanese were not making any of their own riveted mail for whatever reason, they had European mail which had been imported which was riveted, unless it was some second rate export armor.
J
Jean Henri Chandler
Posted: Tue 08 Jun, 2010 12:08 pm Post subject: |
Didn't document slashing tests regarding butted or riveted maille as I wanted to portray the likely weakness in maille(separation of the links). |
Thanks that is interesting nevertheless. Some high resolution photos would be a good idea next time you do a test.
It looked like you pierced the riveted mail in your second attempt ...?
J
Eric S
Posted: Tue 08 Jun, 2010 12:35 pm Post subject: |
Jean Henri Chandler wrote: | I don't know of any European armor from this period which was butted. In fact I'm not aware of any European mail dating to before 1800 AD which was butted, (perhaps someone can correct me if I'm wrong).
J | This is from another forum posted by Timo Nieminen>>>>>
Quote: | From Kozan, The manufacture of armour and helmets in sixteenth century Japan (orig. 1800), pg 83-84 in 1963 Holland Press edition,
"There are several varieties of mail:
... karakuri-namban (riveted namban), with stout links each closed by a rivet. Its invention is credited to Fukushima Dembei Kunitaka, pupil, of Hojo Awa no Kami Ujifusa, but it is also said to be derived directly from foreign models. It is heavy because the links are tinned (biakuro-nagashi) and these are also sharp edged because they are punched out of iron plate." |
If this is true then the Japanese saw riveted mail...made it..and then abandonded it but kept the pattern using butted chain instead...but why? They certainly had all the resources to make and produce riveted mail. All traditional Japanese armor plates are riveted together when not laced and there was no lack of low grade iron, there was a huge cheap workforce and flattening out some wire or punching it out and riveting links wound have been quite easily done...so why use butted exclusively instead?
Jean Henri Chandler
Posted: Tue 08 Jun, 2010 1:03 pm Post subject: |
Eric S wrote: | This is from another forum posted by Timo Nieminen>>>>>
iron plate." |
Quite interesting, thanks for posting.
Quote: |
If this is true then the Japanese saw riveted mail...made it..and then abandonded it but kept the pattern using butted chain instead...but why? They certainly had all the resources to make and produce riveted mail. All traditional Japanese armor plates are riveted together when not laced and there was no lack of low grade iron, there was a huge cheap workforce and flattening out some wire or punching it out and riveting links wound have been quite easily done...so why use butted exclusively instead? |
Riveted mail is not as easy to make as riveted lamellar. The technique may have never been widely disseminated. The bottom-line difference between riveted and butted mail is that butted mail is easier and therefore cheaper to make. If it's armor for town police it may simply not have been that high of a priorrity.
Or maybe it was simply because the occurance of open warfare in Japan declined rapidly in the Edoo period after the ascension of the Tokugawa Shogunate, and armor became slightly more decorative since it was no longer under the direct pressure of the battlefield. There were fewer full scale pitched battles in Japan from 1615-1860 than there were from 1600-1615. The role of Samurai was shifting from soldiers to something more like police and bodyguards.
Also, given that we now know that they did in fact have riveted mail, I'm not yet convinced that riveted mail was as rare as you think it was. Just because it's not widely known in the Japanese armor community may not mean much, it may simply not the type of armor that garners the most interest in the community. There have been countless analagous blind-spots and persistant cliches in the academic and amateur historical communities surrounding Western arms and armor and Historical European Martial arts over the years. Witness the role played by Ewart Oakeshott.
It's also worth pointing out that the methods described in the quote above (using punched rings) is not common for European mail after the early Medieval period, usually it was all-riveted and not particularly heavy, in fact it can be lighter than equivalent butted mail because the wire can be thinner butted mail has to be made of wire of a certain strength (often meaning a heavier gauge) or in many cases it will spontaneously develop a 'moth-eaten' appearance and fall apart under it's own weight. Of course if Japanese mail was usually tempered steel it probably wouldn't have this prooblem as much.
J
Last edited by Jean Henri Chandler on Tue 08 Jun, 2010 1:28 pm; edited 3 times in total
Timo Nieminen
Posted: Tue 08 Jun, 2010 1:16 pm Post subject: |
Eric S wrote: |
They didn't use butted mail exclusively.
Apart from some use of rivetted mail, as noted in the SFI thread, one of the (common) variants of Japanese "double mail", i.e., mail with the upright links connecting the flat links being multiply wound (keyring-style) used solid flat links, so not butted, even partially. Assuming we don't call "keyring-wound" "butted", and we shouldn't, since it's overlapped, not butted. Then there are the styles where the flat rings are keyring-wound as well.
Apart from the above non-butted styles, partially-butted double mail, with butted flat rings, but of very thick wire, was recognised as strong.
Brawn Barber
Posted: Tue 08 Jun, 2010 2:24 pm Post subject: |
J |
Only to the extent of the rings diameter, I believe. With padding not likely to break the skin. However there was an instance in which the "weak link" permitted a breach with the riveted maille. It ended up with a 2" breach. Bear in mind, this was one of a dozen attacks and the links may have already been weakened.
Posted: Tue 08 Jun, 2010 3:14 pm Post subject: |
Brawn Barber wrote: | Only to the extent of the rings diameter, I believe. With padding not likely to break the skin. However there was an instance in which the "weak link" permitted a breach with the riveted maille. It ended up with a 2" breach. Bear in mind, this was one of a dozen attacks and the links may have already been weakened. |
Keep in mind that most of the riveted mail used today doesn't have much in common with historical mail.
http://www.myArmoury.com/talk/viewtopic.php?t=19189
It is fine if you just want a comparison in performance between modern butted mail and modern riveted mail but it won't tell you much about how historical mail might have performed.
Brawn Barber
Posted: Tue 08 Jun, 2010 3:50 pm Post subject: |
Dan Howard wrote: | Brawn Barber wrote: | Only to the extent of the rings diameter, I believe. With padding not likely to break the skin. However there was an instance in which the "weak link" permitted a breach with the riveted maille. It ended up with a 2" breach. Bear in mind, this was one of a dozen attacks and the links may have already been weakened. |
It is fine if you just want a comparison in performance between modern butted mail and modern riveted mail but it won't tell you much about how historical mail might have performed. |
True, and thanks, Dan. I'm just trying to show an associated comparison. If I had my hands on some historical riveted maille, there's no way I'd be tearing into it with such reckless abandon.
Eric S
Posted: Tue 08 Jun, 2010 6:24 pm Post subject: |
Timo Nieminen wrote: | Eric S wrote: |
Apart from the above non-butted styles, partially-butted double mail, with butted flat rings, but of very thick wire, was recognised as strong. | All Japanese mail that I have ever seen is butted or partially butted...here is the double wound links which would not be considered to be butted...but the round connecting links are butted. This is one of the old style Japanese patterns and can see how much open space there is between the links.
Timo Nieminen
Posted: Tue 08 Jun, 2010 7:42 pm Post subject: |
Eric S wrote: | Timo Nieminen wrote: | Eric S wrote: |
All Japanese mail that I have ever seen is butted or partially butted |
That might well be so, I don't doubt it. But that doesn't mean that non-butted mail wasn't used in Japan. Given that we have primary sources describing the existence and construction of such mail in Japan, it's clear that it was used.
That you haven't seen it doesn't mean that it didn't exist. This is why written sources and art can be useful; in the absence of surviving artifacts, it can be all we have to go on (or in the absence of artifacts of reliable provenance).
Eric S
Posted: Tue 08 Jun, 2010 8:16 pm Post subject: |
Timo Nieminen wrote: | Eric S wrote: | Timo Nieminen wrote: | Eric S wrote: |
That you haven't seen it doesn't mean that it didn't exist. This is why written sources and art can be useful; in the absence of surviving artifacts, it can be all we have to go on (or in the absence of artifacts of reliable provenance). | I would love to see some completely non-butted Japanese chain armor turn up....what I meant was, that all the known Japanese patterns use at least some butted links in their construction, even the double twisted ones....there is probably some missing information and or examples hiding some were.....hopefully something will turn up.
Timo Nieminen
Posted: Tue 08 Jun, 2010 8:54 pm Post subject: |
Eric S wrote: |
I would love to see some completely non-butted Japanese chain armor turn up....what I meant was, that all the known Japanese patterns use at least some butted links in their construction, even the double twisted ones....there is probably some missing information and or examples hiding some were.....hopefully something will turn up. |
Not true. We have written primary sources clearly describing non-butted Japanese mail. Sakakibara Kozan, The Manufacture of Armour and Helmets in Sixteenth Century Japan, widely cited in modern works on Japanese armour (e.g., Robinson, Ratti, Bottomley) describes such non-butted mail, of a clearly Japanese pattern. See pp 83-85.
It is simply wrong to say that all Japanese mail was butted.
"Manufacture ..." also decribes rivetted mail, used in Japan, as re-quoted up-thread by you. Whether or not one considers it a "Japanese pattern", it was used in Japan.
Also described is hana-gusari (floral mail), 6-in-1 Japanese pattern. The flat rings are "punched out of solid plate and sometimes riveted", of "modern" make, i.e., Edo period, not known to the author as a pre-Edo style. No details given on the kake-gusari (secondary links), as to whether butted or multiply-wound. If multiply wound, this is a non-butted style.
Further, we have raden-gusari, with both main and secondary links being multiply-wound, usually(?) triple-wound, but sometimes double, "not used in former days", so not known to the author as pre-Edo. He doesn't recommend it - too heavy.
So one source - one of the best known English language source - describes 3 certainly non-butted patterns of mail (two of them certainly Japanese patterns) and one possibly non-butted pattern. Of these, 1 (solid main link, double-wound secondary link Japanese 4-in-1) is described as used pre-Edo.
Posted: Tue 08 Jun, 2010 10:01 pm Post subject: |
One factor to consider is that if riveted maille was first known only with the arrival of Europeans it would be fairly late in the period of active large scale warfare in Japan i.e. big battles on the battlefield as opposed to individual " civilian " combat nearer to duels or small clan feuds where armour would tend to be less frequently used ?
The use of armour as suggested earlier in another post would have become much more " ceremonial " and the practical advantages of riveted versus butted would be less important.
Firearms would also make armour and especially maille armour more or less obsolete except for the use of " secrète " armour protection.
Now the traditional Japanese maille patterns seem effective to me for the somewhat limited auxiliary uses it was put to mostly protecting against draw cut I assume.
The very open weaves would still turn a cut but would be almost useless in resisting a thrust.
Pre-European contact(s) I wonder to what degree the Japanese where aware of the use of riveted maille ? On the Japanese mainland probably very little knowledge or firsthand experience with it or even none at all ! But Japanese expeditions in Korea might have exposed them to riveted maille maybe of Indo-Persian/Mongle/Chinese manufacture ?
Japanese pirates being probably more likely to be exposed to foreign weapons and armour coming from very far regions if they came into contact with mercenaries guards or other pirates coming from regions where riveted maille was the norm ?
Now if the Japanese had been exposed to riveted maille a few hundred years earlier it might have become a dominant form of armour rather than mostly ancillary use in arm defences and occasionally for stand alone defence.
Eric S
Posted: Tue 08 Jun, 2010 10:41 pm Post subject: |
So one source - one of the best known English language source - describes 3 certainly non-butted patterns of mail (two of them certainly Japanese patterns) and one possibly non-butted pattern. Of these, 1 (solid main link, double-wound secondary link Japanese 4-in-1) is described as used pre-Edo. | One written source ( translated from Japanese and written in the 1800s) with no pictures or an known surviving examples.....and how can you have a "solid main link, double-wound secondary link Japanese 4-in-1"?? How would you connect the links??? What you are describing is the picture I just posted...double twisted with butted connecting links..you have to be able to connect the links and since the twisted links act like a solid link the connecting links would have to open up some how.
Timo Nieminen
Posted: Wed 09 Jun, 2010 12:25 am Post subject: |
Eric S wrote: | One written source ( translated from Japanese and written in the 1800s) |
1800. One written source by a writer very familiar with Edo-period armour, and knowledgable about earlier armours. He's also quite willing to write that he doesn't know something when he doesn't know something. The gap separating him from pre-Edo was only half of ours. Is 1800 a problem? Had they stopped making real armour in Japan by then?
If you don't believe him, why not? What in his book makes you so very skeptical? What makes you think that you know better than he did?
Is the English translation so faulty? What is your proposed translation from the original?
Presumably your criticism and dismissal of such a source is based on scholarship and evidence. I'm interested in knowing what's wrong with such a widely cited and well-regarded source.
Eric S wrote: | with no pictures or an known surviving examples.....and how can you have a "solid main link, double-wound secondary link Japanese 4-in-1"?? How would you connect the links??? What you are describing is the picture I just posted...double twisted with butted connecting links..you have to be able to connect the links and since the twisted links act like a solid link the connecting links would have to open up some how. |
The descriptions are very explicit. Solid main links, completely unambiguous. Note well that he also describes what you pictured, double-wound secondary links and butted main links. He clearly knew the difference between the two, and clearly distinguishes between them.
How would you connect the links? With the double-wound secondary links. This is clearly possible - else how could they have made mail with triple-wound main and secondary links?
