Damian Sulowski
Posted: Mon 18 May, 2020 1:28 pm Post subject: |
Michael Beeching wrote: | The fittings remind me a lot of my class with Ric Furrer!
Forging and grinding fittings is quite enjoyable, but it's also a LOT of work. It makes you understand why so many makers go for castings when it comes to production swords, though the castings generally aren't as good or as tough as a forged part (just the nature of a casting).
I also have a question, if you don't mind answering: I have a project in the works, and I want to make a simple sword guard. I believe we have A36 mild steel stock at work, and I should be able to get a piece. To form the guard, I would just use stock reduction as I currently lack any forging facilities. Would simple stock reduction produce a suitable guard? Although mild steel is generally not hardenable, I do wonder if you can make it tougher through the heat treating or forging processes. A very broad question, but if you'd not mind offering some advice here, I'd really appreciate it! |
Hi
If you want to make the sword - a reconstruction - to combat with the blunt edge, then the crossguard should be hardened.
You should use the steel C45 or 51CRV4.
And if the sword will be used for cuting or you make the sword just to your collection, then the crossguard can be not hardened.
The steel A36 is using in production of pipes and steel tanks and it can not be hardened. But you can make it harder if you will warm
it to red colour (red minimum - yelow maximum), and then you can put it in rapeseed oil or wather. The best what you can do is hammer the whole piece to
change the structure. This process will be not hardening process but it will make the steel strong and stiff.
I used the steel like A36 some time ago when I was making balustrades and fences. The best will be a rod 18mmX18mm then you will easy make the hole.
You can aways write - I will answer for your all questions
https://www.facebook.com/sulowskiart/
Damian Sulowski
Damian Sulowski
Michael Beeching
Posted: Sun 24 May, 2020 10:43 am Post subject: |
Beautiful, Sir!
Also, thank you very kindly for your reply to my inquiry. That meant a lot to me.
J.D. Crawford
Posted: Sun 24 May, 2020 2:23 pm Post subject: |
O yeah, that's a classic. Looks like the Soborg sword but maybe wider. What are the dimensions?
Damian Sulowski
Posted: Mon 25 May, 2020 12:58 pm Post subject: |
J.D. Crawford wrote: | O yeah, that's a classic. Looks like the Soborg sword but maybe wider. What are the dimensions? |
Thank you for comment. This is not Soborg sword, this is Viking Type with a width fuller. The blade is long because it is 86cm. But the width of the blade is 5cm. I will give all dimentsions when the sword will be rady because now I work on the crossguard and the pommel to make it with old facture.
J.D. Crawford
Posted: Mon 25 May, 2020 3:05 pm Post subject: |
Damian Sulowski wrote: | J.D. Crawford wrote: | O yeah, that's a classic. Looks like the Soborg sword but maybe wider. What are the dimensions? |
Thank you for comment. This is not Soborg sword, this is Viking Type with a width fuller. The blade is long because it is 86cm. But the width of the blade is 5cm. I will give all dimentsions when the sword will be rady because now I work on the crossguard and the pommel to make it with old facture. |
Is it a commission or will it be up for sale?
Matthew Stagmer
Posted: Mon 25 May, 2020 3:18 pm Post subject: |
Fantastic process ! Your work is so clean !
Matthew Stagmer
Youtube.com/ThatWorks
Damian Sulowski
Damian Sulowski
Henry R. Gower
Posted: Wed 27 May, 2020 9:59 am Post subject: Workshop process |
Damian, It is a real pleasure to see how the swords and scabbards are made. Being able to appreciate the details, the pommels, forming the recess in the guard to secure the blade, the chape. Thank you for all the splendid photographs.
Henry
Damian Sulowski
Posted: Wed 27 May, 2020 11:56 pm Post subject: Re: Workshop process |
Henry R. Gower wrote: | Damian, It is a real pleasure to see how the swords and scabbards are made. Being able to appreciate the details, the pommels, forming the recess in the guard to secure the blade, the chape. Thank you for all the splendid photographs.
Henry |
Thank you Henry. It is a great pleasure to put here some photos of my work. And I am happy that you and some other people like it. Greetings.
Damian Sulowski
Michael Beeching
Posted: Mon 01 Jun, 2020 12:24 pm Post subject: |
Damian,
Are you actually staking the guard in place? If so, I've not seen that before!
Tyler C.
Posted: Mon 01 Jun, 2020 2:01 pm Post subject: |
I like the look of the black oxide fittings. I see black fittings in period artwork of this age on occasion so it could very well be a period correct finish.
Damian Sulowski
Posted: Tue 02 Jun, 2020 9:25 am Post subject: |
Michael Beeching wrote: | Damian,
Are you actually staking the guard in place? If so, I've not seen that before! |
Yes I usualy make it in this way, then the guard is immobile . There are some examples of this method in history. Offen the guard was also forged from the side and pressed to the fuller. There are many examples in history that the whole in crossguard was too loose and then it was immobile with the handle. I think that most of swordmakers make it in this way.
Damian Sulowski
Posted: Tue 02 Jun, 2020 9:29 am Post subject: |
Tyler C. wrote: | I like the look of the black oxide fittings. I see black fittings in period artwork of this age on occasion so it could very well be a period correct finish. |
Thank you. It was an idea of my clien and I think it look very good. it is not hemical oxide. It is made in vey high temperature - the surface is partly burned out - it is something like antiques.
Damian Sulowski
Damian Sulowski
Posted: Sat 06 Jun, 2020 6:52 am Post subject: |
Hello my friends. I want to show you our last work. It was a special order that gave us a lot of emotions. It is a sword type X from X-XIth. century.
The blade is type 5 in Geibig's classification. It is a long, big blade and it has incredible blow strength.
All elements are full handmade - forged blade, holes in the crossguard and pommel forged in a traditional way and a socketforged by hand from sheet of
metal. Photos of the process you could seen in my posts.
The pattern on the scabbard was carved in 3D way. without the punches with a ready pattern and without ready-made rollers.
I hope you will enjoy our work - I invite you to fallow our page and to share this post.
Viking sword type X
Full functional, made with high quality steel 51CrV4 (6150)
Hardened 54HRC,
Total lenght: 100,5cm,
Blade lenght: 86cm,
Blade width at the base: 5cm,
Balance: 14,5cm,
Grip lenght: 10cm,
Weight 1250g,
Edge is sharp
movie: https://www.youtube.com/watch?v=zJrGwKa1h3g
more photos: http://historicalswordszone.com/viking-sword-type-x/
Attachment: 198.71 KB
Attachment: 196.16 KB
Attachment: 122.63 KB
Attachment: 190.94 KB
Damian Sulowski
